Error Reproducing Video
Turn your outdoor training into My RealVideo!
raschultz
Postby raschultz » Thu Apr 09, 2020 11:58 pm
Every one of the MyRealVideos ive downloaded to run give the following error. See attachment 2.
Example, Alpe d'Huez looks like it downloaded fine (attachment Huez1) but when I try and run the program I get the following error (attachment Huez2). What's the fix?
Downloaded file, clicked on play icon
Error
raschultz
Re: Error Reproducing Video
Postby raschultz » Fri Apr 10, 2020 12:02 am
Course looks to be 9 miles long - As soon as click START, I immediately get TRAINING ENDED.
So far, every video I've tested errors out.
What's the fix?
pruvost.pa@free.fr
Postby pruvost.pa@free.fr » Sat Apr 11, 2020 7:54 pm
Bonjour
j'ai le même message d'erreur avec une vidéo que j'ai mis en ligne ( Col des saisies). Il semble que ce soit la qualité de l'enregistrement qui est trop forte. J'attends la réponse des programmeurs de Elite mais pour le moment je n'ai toujours rien reçu.
Si vous avez un résultat je suis intéressé
merci
P Pruvost
darwader64
Postby darwader64 » Sat Apr 18, 2020 12:39 pm
Hello
¿Why are the videos not verified before putting them for download? I have tried several and they present different errors.
18407288 Fecchio (damaged)
18689702 Bobbin Head (damaged)
18906716 Chilton Heights (Lots of vibrations. Hinder your vision)
19039600 Sankt Andrae (damaged)
19241591 Kiroldegia urtatzako pantanoa (until the middle of the video doesn't advance, circulates through pedestrian areas and forbidden direction, stops to speak)
They should improve these aspects if they want to have more users.
Postby Elite Admin S » Wed May 27, 2020 11:28 am
There are a lot of new videos every day. We cannot check them one by one and we trust our users to not upload bad videos (or at least to delete them when they notice)
michel.mesnier
Postby michel.mesnier » Fri Aug 28, 2020 9:39 am
Bonjour
I have the same error it seems indeed that the player does not support some format whereas same video works on other pc/device.
Do you have solve your issue?
What is the answer from support?
What was the solution?
J ai le même problème. Cela semble venir du fait que le player ne supporte pas certains formats. Cependant la même vidéo fonctionne bien sur d autres appareils (pc inclus).
Quelle est la réponse du support ?
Avez vous résolu le problème ?
Quelle est la solution ?
Merci
Return to “myRealVideo”
