HI Folks,
It is my understanding that when you play a Myrealvideo via MyEtrainer it should automatically change the setting within your trainer (assumes interactive trainer etc). This is based upon the terrain / slope etc
Please tell me I am right or wrong.
I believe this is called simulation mode
Cheers
Should Myrealvideo automatically adjust your interactive trainer
keithkemble157
basicpermit
Re: Should Myrealvideo automatically adjust your interactive trainer
keithkemble157 wrote:HI Folks,
It is my understanding that when you play a Myrealvideo via MyEtrainer it should automatically change the setting within your trainer (assumes interactive trainer etchappy wheels). This is based upon the terrain / slope etc
Cheers
Recording from a car is not a problem, but you should try to keep an appropriate speed.
You should drive with a speed as close as possible to the speed you'd have by bike.
I know that this is almost impossible of course, but try to go slow if you can. Otherwise, the video will be less fluid when you'll reproduce it on your trainer.
