myETraining Not Working
I own a Note 8 which earlier was running Android 7.0. Today I updated to Android 8.0 and now app is only displaying white blank screen when opened and closing itself automatically after few seconds. Can anyone please help me fix it asap?
Garry x Tech enthusiastic and YouTuber.
https://showbox.onl/ https://getmobdro.com/ https://dltutuapp.com/
Re: myETraining Not Working
Try uninstalling the app and installing it again. If the problem is not solved, write to the customer care at real@elite-it.com
The same Problem My ETraining Not Working On Android Orea whenever I am opening the app it is simply crashing upon the startup.
Update: I’ve uninstalled and reinstalled the latest version of the My ETraining app and it’s working just fine again :slight_smile:
possess a Note 8 which prior was running Android 7.0. Today I refreshed to Android 8.0 and now application is just showing white clear screen when opened and shutting itself naturally following couple of moments. Would anyone be able to please enable me to settle it asap?
Regards,
Pluto tv Apk
Showbox for chromecast.
Regards,
Pluto tv Apk
Guys,
uninstall the app and install it again. This should solve the issue.
If it doesn't work, contact the customer care at myetraining@elite-it.com
Hello all!
Regards,
Regards,
Hai dear,
some times some mistakes will be happen.. so ETraining also not working.
Regards,
peterhean
http://www.flipacliponline.com/flipaclip-unlocker-apk-download
http://www.flipacliponline.com/flipaclip-cartoon-animation-apk
Regards,
peterhean
garryjoshi wrote:I own a Note 8 which earlier was running Android 7.0. Today I updated to Android 8.0 and now app is only displaying white blank screen when opened and closing itself automatically after few seconds. Can anyone please help me fix it asap?
I'm also same Problem My ETraining Not Working On Android Orea whenever I am opening the app it is simply crashing upon the startup.
android development company
This is a very good post and informative post kindly check this post.
Users browsing this forum: No registered users and 55 guests
