I just have bought a Kura.
I've already paired with my Garmin Edge 520. I've found on that forum the wheel setup to it (2105/3,43=614mm).
Trying to work with your own app via iPhone, I've managed to pair the power sensor and the sensor called CSC. Not the cadence nor the HR of my Garmin device.
Going to advance configuration and also going to "power smoothing" or "calibration of trainer sensor" it appears "start pedaling" but nothing happens. It goes the same way when choosing "trainning".
I've not been able to pair the Kura with Zwift using the iPhone app. Any sensor is found.
Thanks,
Kura hometrainer
Re: Kura hometrainer
It seems that you're already in contact with our customer care.
A technician has answered to your request the 9th of december and is waiting your reply, if you haven't seen the email please check on your spam folder
Users browsing this forum: No registered users and 61 guests
