Elevation is way too smooth after import
hernandez_christ
Postby hernandez_christ » Wed Apr 07, 2021 10:15 pm
I have a route (82,6km ; 926m elevation) as gpx which I wanted to import into myEtraining. First problem is the app seems to support only kml. Well I found a way to convert and then I can import in the app.
The route is well retrieved but I don't see any info about the total elevation. When I display the route profile I see some curve way too smooth.
Did someone noticed the same? While riding will I really follow this poor elevation or the real one?
I can control my suito with my bike computer but the screen of my tablet is bigger. It is already boring enough to ride without video, so having to use a bike computer would be crazy on such distance.
hernandez_christ
Re: Elevation is way too smooth after import
Postby hernandez_christ » Thu Apr 08, 2021 10:00 pm
Any body has already imported a route?
Below what I get in myEtraining versus what I get in garmin (exact route) or even in naviki (not perfect, yet better than myEtraining)
MyEtraining route profile
Garmin
Naviki
hernandez_christ
Postby hernandez_christ » Sat Apr 10, 2021 9:40 pm
The same imported in rouvy.
Is there a setting in my e training to keep all gps positions and not filter them?
hernandez_christ
Postby hernandez_christ » Wed May 12, 2021 9:18 pm
Even if there was no reply here I'll update the status. Indeed a ticket has been taken care of by the admin of the forum and a problem has been found on the Android app while importing a route (import seems OK on windows). A first update of the app has been published 2 weeks ago but still it is not perfect so developers are again working on it.
By the way if I want to connect my suito to my laptop, can I use the Bluetooth connection or an ant+ is mandatory?
Postby Elite Admin S » Thu May 13, 2021 9:28 am
ant+ is not mandatory, you can also use Bluetooth but you have to check if your pc supports bluetooth 4.0 or higher
