Direto pedaling analysis works fine i my-e-training windows version via ant+ but on ipad vesion via bluetooth pedaling analysis just show min=0 and max=65535 on the graphs(first 2 screens) any idea why
on the last screen(3) where (min,avg,max power cadence speed HR Uniformity) min power is 0-50w avg is 32.8xx,x(stays in the 800 range) and max power is always on 65535 it don´t flux
cadence,speed,hr seems to be right
and why is the no pedaling analysis in android app
i shut give guinness world records a call vent i can make 32.805,8watts or join the tour de france
Re: Direto pedaling analysis
Sorry, it's our fault.
The pedal analysis for Direto was not completed in the latest update of the app. The development team was working on it and they have forgotten to disable the button when they release the update. So, that's why you can run it but it doesn't work.
Now the pedal analysis has been completed and it is under test in these days, we will release a new update that fix it by the end of next week.
Is The Pedaling analysis available for Direto on android platform ???
I confirm you that it is available
Can I ask do you use an additional external cadence sensor to get the pedaling analysis working in Windows? Or are you just using the cadence of the Direto
hi
elite told me to use there cadence sensor kit to get pedaling analysis to work on direto
https://www.shopelite-it.com/en/spare-p ... sensor-kit
so the pedal analysis work and it now works on all platforms (android,IOS,windows)
don´t know if it works with other cadence sensores
Thanks for your reply and clarification and link.
Think they need to add this info into their manual indicating the additional purchase of the pedaling analysis software and cadence sensor.
Thankyou
Thankyou
or just include the cadence sensor with the trainer
and pedaling analysis only listener to the data so it ca be used a long side other apps/software
dreaming......riding on zwift(controls trainer) and have pedaling analysis listener to the data to show padeling data on other device
shane miller have made youtube clip about pedaling analysis
The documentation online notes there is a place in the Settings where you can optimize the placement of the Elite external integrated sensor, but I can't seem to find it. Is this not available on the Direto?
Users browsing this forum: Bing [Bot] and 22 guests
