Page 1 of 2
export training to STRAVA
Posted: Thu Sep 28, 2017 3:34 pm
by Lavapo@hotmail.com
When i send my REAL VIDEO etraining to STRAVA, i can't see the map where i "cycled", only the data....
is it possible to import the map?
So when you did the Ventoux ride you also see the ventoux map in STRAVA?
Re: export training to STRAVA
Posted: Fri Sep 29, 2017 10:57 am
by Elite Admin S
I'm sorry but by now the export function only consider the training data (speed, power, cadence...) and not the map data (map, altimetry...)
Posted: Thu Dec 07, 2017 4:34 pm
by ms312
Is it possible that importing map will be possible soon ???
Posted: Thu Dec 28, 2017 10:39 pm
by sigvind
I would like this too, i.e GPS coordinates included in tcx exports. Is there still a plan to fix this, as was informed back in 2015, or did you give it up for some reason?
Is this a problem with Strava not allowing virtual rides?
Posted: Tue Jan 16, 2018 6:52 pm
by flavioargent
I wanted altimetry to appear, same as zwift
Posted: Sat Jan 20, 2018 9:35 am
by PierreJ
I would enjoy map datas as well, you really should do this, most of training programs allow it. thx.
Posted: Sat Feb 03, 2018 12:03 pm
by david.obber
me too!
it's more than a nice-to-have feature.
The integration with Strava is a great plus for an application, but it should be completed. Does it take a great effort to add gps data to the workout?
Posted: Sat Feb 03, 2018 12:10 pm
by Pancreata
I posted about this also, my message has not appeared.
I won't be using myrealvideo anymore, as I need to export map/location, gradient (max, av, etc.) total ascent. These features are all available when I use Bkool, VeloReality, Garmin Connect and BigRingVR.
Posted: Sat Feb 03, 2018 4:27 pm
by Pancreata
Me too. No point in data without the map, gradient & ascent data.
Posted: Mon Feb 05, 2018 9:30 am
by Elite Admin S
@Pancreata,
Sorry, first post in the forum (and also new threads) needs the admin approval (it's not for censoring them, of course, but to avoid phishing and spamming and other weird things). But it's a quite busy period of the year so we don't check the forum posts daily (usually weekly, but it depends).
