EliteMyTraining Training Test Phase 3
Jone
Re: EliteMyTraining Training Test Phase 3
Postby Jone » Fri Feb 16, 2018 11:03 am
up!
Jone
Postby Jone » Tue Feb 20, 2018 6:24 pm
have you fix this issue yet?
Postby Elite Admin S » Thu Feb 22, 2018 10:37 am
I confirm you that it has been solved
Jone
Postby Jone » Mon Feb 26, 2018 8:17 pm
Hello
Tested today and does not increase trainer resistance when hr goes down in final 10min. phase.
Target hr is 161 beats and hr goes lowest at 151 beats in final minutes.
My old turbo muin unit you can control manually power that you output and you can maintain steady target hr in final 10min. and the test result is much different.
Trainings that software generates in erg mode (direto) are way too easy, you can't reach your target hr in sweetspot or interval area.
Must hit manually about 30 watts more in sweetspot and interval area to get target hr.
Changelogs doesn't say anything that problem has been solved. I bet that problem is all your trainers which use erg mode in training test.
martinfinnemann
Postby martinfinnemann » Tue Mar 13, 2018 6:30 pm
Well....
Just did a test today... And could not be further from what was suppose to happen in test phase 3.
The resistance just kept going up, till I had to stop the test.
Is there a solution to do a proper test in the app?
Even though I would love to have a threshold power like the test showed, I doubt I am in that kind of shape.
lyndonthompson.mob
Postby lyndonthompson.mob » Mon Nov 05, 2018 2:59 am
Elite Admin S wrote:I confirm you that it has been solved
No it hasn't. Same thing happened to me in the Real software today.
mabruk66
Postby mabruk66 » Wed Nov 07, 2018 12:39 pm
Sorry for the delayed answer.
To solve this problem follow these steps:
1. Open the My-E-Training app.
2. Press the "Parameters" red button.
3. Enter the "Advanced Configuration"
4. Enter the value "10" in to the "Power smoothing".
After this procedure your problem will be solved.
Important: Try to maintain a very smooth constant cadence in the test till it finishes.
