EliteMyTraining Training Test Phase 3
Re: EliteMyTraining Training Test Phase 3
have you fix this issue yet?
I confirm you that it has been solved
Hello
Tested today and does not increase trainer resistance when hr goes down in final 10min. phase.
Target hr is 161 beats and hr goes lowest at 151 beats in final minutes.
My old turbo muin unit you can control manually power that you output and you can maintain steady target hr in final 10min. and the test result is much different.
Trainings that software generates in erg mode (direto) are way too easy, you can't reach your target hr in sweetspot or interval area.
Must hit manually about 30 watts more in sweetspot and interval area to get target hr.
Changelogs doesn't say anything that problem has been solved. I bet that problem is all your trainers which use erg mode in training test.
Well....
Just did a test today... And could not be further from what was suppose to happen in test phase 3.
The resistance just kept going up, till I had to stop the test.
Is there a solution to do a proper test in the app?
Even though I would love to have a threshold power like the test showed, I doubt I am in that kind of shape.
- Screenshot_20180313-181833.png (85.08 KiB) Viewed 8562 times
- Screenshot_20180313-181937.png (100.54 KiB) Viewed 8562 times
Elite Admin S wrote:I confirm you that it has been solved
No it hasn't. Same thing happened to me in the Real software today.
Sorry for the delayed answer.
To solve this problem follow these steps:
1. Open the My-E-Training app.
2. Press the "Parameters" red button.
3. Enter the "Advanced Configuration"
4. Enter the value "10" in to the "Power smoothing".
After this procedure your problem will be solved.
Important: Try to maintain a very smooth constant cadence in the test till it finishes.
- Screenshot_2018-1.png (172.32 KiB) Viewed 7561 times
- Screenshot_2018-2.png (86.5 KiB) Viewed 7561 times
- Screenshot_2018-3.png (101.87 KiB) Viewed 7561 times
Users browsing this forum: No registered users and 54 guests
