Felicidades nuevo FTP Test
Muchas felicidades por agregar el FTP test a la app y programa de My e-traning, me resulto muy efectivo para medir mi FTP, espero sigan mejorando las aplicaciones.
Sergio Alvarez
Guerrero, Mexico
Guerrero, Mexico
Re: Felicidades nuevo FTP Test
A mi tambien me ha servido mucho el FTP Test, comparto tus agradecimientos con esto
Gracias, me alegra mucho que te haya gustado
Buenas,pues el programa FTP test es una verdadera mierda.No sirve para nada.Tienes que hacerlo siempre con el rodillo al mínimo de fuerza y así es imposible pasar de 250 w a no ser que hagas 1000 rpm,puse una queja hace meses y todavía no han hecho nada.ds una pena pagar para algo que no sirve para nada.
Hi, a few months ago I contacted the elite commenting that the FTP test could not be done well. First they tell you that the roller has to be at the minimum power level, it seems right. They command you to warm up for 20 minutes at low power and then tell you to do 3 phases at max and min intervals. Well on my bike the max with large plate (3 plates) and small pinion do not pass 250w at 400 rpm. Then, another 10 min of low intensity, well, But then another 10 to max, with the regulation set to the minimum it is impossible to do ten minutes, the first thing that you do not get watts, and the rpm goes crazy, if I can attach a video in which vary from 200 to 400 RPM. In his day I commented that they should be able to regulate the level of intensity of the roller, which is why it is. For example, in the test that I have done today, 208 came out with an average power of 168 W and the FC over 150. So to compare one day I did an hour roll, I got 245 w and a FC of 158, with a cadence of 91 w. I find it regrettable to be paying for a product that does not work, or at least I am the only fool, who does not know how to do it, who also can be. The 208 that have left me today, my boy does with 6 years and without sweating. Some solution they have to give, and if they do not give me back the money, or when they solve it, extend the time I have been without being able to use this function.
Greetings to all.
Greetings to all.
- IMG_20190607_122228.jpg (117.58 KiB) Viewed 6062 times
- IMG_20190607_112042.jpg (176.24 KiB) Viewed 6062 times
- IMG_20190607_110820.jpg (105.38 KiB) Viewed 6062 times
alvarezkeko wrote:Muchas felicidades por agregar el FTP test a la app y programa de My e-traning, me resulto muy efectivo para medir mi FTP, espero sigan mejorando las aplicaciones.
do not pass 250w at 400 rpm. Then, another 10 min of Audacity Find My iPhone Origin low intensity, well, But then another 10 to max, with the regulation set to the minimum it is impossible to do ten minutes, the first thing that you do not get watts, and the rpm goes crazy, if I can attach a video in which vary from 200 to 400 RPM. In his day I commented that they should be able to regulate the level of intensity of the roller, which is why it is. For example, in the test that I have done today, 208 came out with an average power of 168 W and the FC over 150. So to compare one day I did an hour roll, I got 245 w and a FC of 158, with a cadence of 91 w. I find it regrettable to be paying for a product that does not work, or at least I am the only fool, who does not know how to do it, who also can be. The 208 that have left me today, my boy does with 6 years and without sweating. Some solution they have to give
