Apple watch as heart rate sensor
It looks like I'm not able to use iWatch as the heart sensor any plans to add this to the app?
Re: Apple watch as heart rate sensor
I was wondering this myself.
Sorry guys, the apple watch is not compatible with our app.
Exactly,unfortunately apple watch is not compatible with this app..I hope it will be compatible soon
Elite Admin S wrote:Sorry guys, the apple watch is not compatible with our app.
Ok. Just not now or not planned at all in the future?
You should consider market opportunities introducing a feature like that.
The problem is how the device transmits to the external.
If a device doesn't send data out in a standard way, there's no much we can do unfortunately.
zwift manages to do it.
It is possible - you guys must come up with a solution.
Anche a me interesserebbe questa funzione. La soluzione sarebbe che i programmatori scrivessero una versione per iPhone E Apple Watch, in modo che possa mandare i dati del battito e registrarli insieme agli altri dati. Molte applicazioni su App Store lo fanno, ma non sono perfettamente compatibili con il sensore Misuro B+. Un'altra cosa correlata sarebbe l'esportazione automatica dei dati nell'app Salute di Apple...
I need this function too. Solution is that the app developer will make a version for iPhone AND Apple Watch, so it can send hearth rate and record it with the other metrics. A lots of app in the market can do this, but they are not perfectly compatible with the Misuro B+ sensor. Another related thing is the auto export in the Apple Health app...
Users browsing this forum: jurgimadariaga and 2 guests
