Settings
Posted: Tue Oct 09, 2018 8:21 pm
by piotrowski.damian
What this function do:
- Power Meter Link
- Power smoothing
Damian
Re: Settings
Posted: Wed Oct 10, 2018 8:45 am
by Elite Admin S
Power meter link
This function is available on Zumo only (by now) and allows having much more accurate power data.
This function allows Zumo to use a power sensor present on the bike as power source. This way, Zumo is more precise since the power data
measured by the sensor are more precise than those Zumo can calculate with its formulas.
Note: this function cannot be used if no power sensor is installed on the bike.
Power smoothing
Power smoothing is available for all the trainers that have an internal power sensor (Direto, Drivo, Drivo II, Kura).
It manage how much smoothed the power value is.
As these trainers are very precise in reading power, the value you'll see on screen will oscillate continuously (in fact, it's normal to have variations between the pedal strokes). Some users prefer to have a more stable visualization of power, so we have added this option.
The higher the value, the more "averaged" will be the power.
