Settings
piotrowski.damian
Settings
Postby piotrowski.damian » Tue Oct 09, 2018 8:21 pm
What this function do:
- Power Meter Link
- Power smoothing
Damian
Re: Settings
Postby Elite Admin S » Wed Oct 10, 2018 8:45 am
Power meter link
This function is available on Zumo only (by now) and allows having much more accurate power data.
This function allows Zumo to use a power sensor present on the bike as power source. This way, Zumo is more precise since the power data
measured by the sensor are more precise than those Zumo can calculate with its formulas.
Note: this function cannot be used if no power sensor is installed on the bike.
Power smoothing
Power smoothing is available for all the trainers that have an internal power sensor (Direto, Drivo, Drivo II, Kura).
It manage how much smoothed the power value is.
As these trainers are very precise in reading power, the value you'll see on screen will oscillate continuously (in fact, it's normal to have variations between the pedal strokes). Some users prefer to have a more stable visualization of power, so we have added this option.
The higher the value, the more "averaged" will be the power.
stephangrobin
Re: Settings
Postby stephangrobin » Tue Nov 27, 2018 8:41 pm
Does power smoothing change how the trainer reacts or just how it is displayed on the graph?
TheRealGioberti
Re: Settings
Postby TheRealGioberti » Thu Dec 27, 2018 9:42 am
Hi there,
My Direto default value is 2 for this setting. What is the valid range for this option?
Thanks in advance.
scoob
Re: Settings
Postby scoob » Sun Feb 03, 2019 6:01 pm
When I click on this option for my Drivo II it comes back with a 2.
Like the other thread - surprised no reply from admire to the question - does this affect how the trainer reacts ?
Users browsing this forum: Bing [Bot] and 15 guests
