Had happened various times before also, but always solved the problem with disconnect/connect or restart pc/third part program.
Now nothing seems to help.. Tryed sw update, BT, ant+, another computer etc. It will connect like normal, but not provide smart resistance in either normal or erg mode.
Serial number XRC212744
Direto XR T no longer provide various/smart resistance.
Re: Direto XR T no longer provide various/smart resistance.
The problem may be on the internal motor or on the electronic board.
First thing to try is to clean the motor screw as indicated in this link:
https://elitesrl.zendesk.com/hc/en-us/a ... rew-thread
If this won't solve the problem, contact our support:
