Hi, im using a cheap bike with solid bolt axle.
It doesnt fit. Qubo handle is too short.
Is there a way to make this work?
Elite qubo mag smart b+ didnt fit
Re: Elite qubo mag smart b+ didnt fit
Can you tell me the diameter of the axle?
Hi, thank you for your reply. I manage to solved the problem by adding another m10 screw on one side of the axle. So now I can hook the bike however I now have a new problem.
On the remote I turn the settings to 1 and now I cant turn it back to 8. The remote wont move from 1 it stuck there. Is the unit broken?
