My suito trainer is reporting really high km/s when training.
For example, my last ride..
Avg Speed: 78.3km/h
Max Speed: 96.5km/h
I suspect it is something to do with the configurable wheel circumference but using the the myETraining app to configure it doesn't seem to work. And anyway, the app doesn't indicate the units that I should be providing for the circumference so i have no idea how to fix it. I'm running 700c wheels btw.
Dan
Suito - Really high Km/s
Re: Suito - Really high Km/s
If you use a 700c wheel, circumference value should be around 2130mm.
Did you set a similar value in the settings?
Thanks for your help. Entering a circumference of 2130mm worked the second time of trying.
Thank you,
Dan
Thank you,
Dan
