Oil leak on Qubo Digital Smart B+
Posted: Fri May 22, 2020 1:41 pm
by andy_gutteridge
Hi - my trainer has started leaking oil. It leaks onto the roller (and the gets sprayed up the wall....
). Any advice on if this can be fixed and how ?
Andy
Re: Oil leak on Qubo Digital Smart B+
Posted: Mon May 25, 2020 9:23 am
by Elite Admin S
The Qubo Digital doesn't have any oil in it.
Probably you've put too much grease/oil on the cassette and chain. When you pedal, it sprays from the chain to the wall
Give it a check!
