Shift Lever not working
Hello, I have a Qubo power Mag smart +. The shift Lever is not working. I bought the product in 2017 is out of warranty and I have no authorized center probably 2000 km from my city. Can you send a disassembly and assembly guide for the shift Lever?
Re: Shift Lever not working
I have the same problem
In my case, the little stop near the screwdriver doesn’t work properly on the little cilindrial spring, unfortenately I dissambly all the knob, with it’s epicicloidal mechanism and and the big round spring, now I m trying to mount in the correct way, may be some wd 40 on the assembly would have work
- E7139C80-0EEC-4723-8FC1-0A078772E5FF.jpeg (26.07 KiB) Viewed 16692 times
cse256 wrote:In my case, the little stop near the screwdriver doesn’t work properly on the little cilindrial spring, unfortenately I dissambly all the knob, with it’s epicicloidal mechanism and and research paper examples about it and the big round spring, now I m trying to mount in the correct way, may be some wd 40 on the assembly would have work
Good job from you. Did you fix it? wd 40 is working ok?
Did you guys found a way to fix it?
cse256 wrote:In my case, the little stop near the screwdriver doesn’t work properly on the little cilindrial spring, unfortenately I dissambly all the knob, with it’s epicicloidal mechanism and and the big round spring, now I m trying to mount in the correct way, may be some wd 40 on the assembly would have work
I applaud your efforts. Is it working now? The WD-40 is fine, right?
Please contact our support before disassemble a trainer.
We can give you instructions and tell you what you can do by yourself and what needs special equipment.
Here you can raise your ticket, we reply usually within 1 day:
Users browsing this forum: No registered users and 38 guests
