I am noob in indoor training environment but have been riding outdoors since an year and half. Recently, I have procured Suito from Elite to keep my passion in Cycling alive. Right from the very first day, I have observed that the resistance on the trainer is very hard. Even if I am riding on flats, the pedal push is like I am on climb. Whenever, I am climbing at 4%, I feel fatigued and stressed.
I have observed that the resistance is unpredictable and Suito decides all of a sudden that it needs to ride hard. I am actually not enjoying my rides due to the missing smoothness while I am riding indoors
Resistance Issue on Elite Suito
Re: Resistance Issue on Elite Suito
Hi, how are you using the Suito, i.e. which app are using? Suito has to be controlled by an app to set the power.
I have smilar issues using zwift in the Free ride mode (ERG off). The suito just keeps on cranking up the resistance as I triy to increase cadence to 70-80 ( Watts are then > 400 I would have to push) , making it impossible for me to to train.
Firmware is up to date, linked to Zwift via BT.
Any Ideas any one?
Best, Timo
Any Ideas any one?
Best, Timo
First of all, do a calibration.
Remember to do a 10 minutes training at around 20 km/h (100-150W) before running the calibration.
If still you are having the feeling that simulation is not realistic, please contact our customer care at myetraining@elite-it.com.
I am using Zwift for training and for the Calibration, I have tried both Zwift and Elite app but still I feel that the tension is very tough. Even if ERG is off, the trainer becomes too tight to push even on flats. I tried Elite training app and my spin down calibration first was 11045 and then again 11035. I do not know, what is the issue and what do I do with these codes.
Please contact the customer care, it's necessary to investigate further
I've had my Suito for a month and it worked OK. However, yesterday when I did a power based training session I noticed ridiculously fast speeds.I reclabrated it and tried again; but no change. I went on to a MyRealtimeVideo and the machine was almost impossible to turn over. I went to Zwift and it kept a huge resistance. Is the trainer faulty or am I missing something?
Usually a fast speed is due to wrong circumference value.
Sometimes, some external devices (like Wahoo Elmnt Bolt) can modify the circumference value and cause such problems.
Run my e-training again and check the circumference value you've set.
Then run a level mode training and check if speed is still wrong.
If the problem persists, contact our support:
https://support.elite-it.com/
