Canyon Speedmax CFR not fitting on the Turno
henry.5
Postby henry.5 » Sun Jan 26, 2025 7:40 pm
I have tried to fit my new Canyon Speedmax CFR on the Elite Turno but it seems that the bike is not compatible?
I wonder if I'm doing anything wrong or simply doesn't fit.
Main problem is that the frame touches on the plastic part of the trainer and prevents me from reaching the Thru-Axle hole to attach the bike.
I've tried with both combinations with no luck
1- Shimano 105 11speed SPRocket
2- Shimano Ultegra 12speed sprocket
tonyadams
Re: Canyon Speedmax CFR not fitting on the Turno
Postby tonyadams » Thu Mar 26, 2026 4:03 am
Your Canyon Speedmax CFR is most likely incompatible with the Elite Turno due to the aero frame design interfering with the trainer housing, not because you installed it incorrectly Subway Surfers or the cassette is faulty.
Return to “Smart Trainers”
