Did my Direto just break? Crank wouldn't turn then resistance inconsistent
Did my Direto just break? I got on it to do a workout and it was pedaling fine, then the crank would barely turn, and now the resistance is really inconsistent and jerky. I tried adjusting the belt resistance to see if that might fix it, but it did not. Pedaling is jerky and there's a bit of a clicking noise coming from the trainer.
Re: Did my Direto just break? Crank wouldn't turn then resistance inconsistent
I am having the same issue. It just started today. Have you heard of any fixes for this?
Thanks,
don
Thanks,
don
Did you get this sorted out? I had a very similar issue on my Direto but in my case the drive belt turned itself inside out and came off. I refitting and tensioned it but after 10 days of normal use, this evening the drive belt snapped.
Guys,
it is clearly an hardware issue. Please contact the customer care at real@elite-it.com and specify the serial number of the trainer
