hi has anyone has any issue with power when using garmin edge 530 workout with directo XR?
i have issue with directo the power cannot up keep with garmin workout. from 250w drop to 150w has some issue.
not sure anyone else has this issue as well.
https://prnt.sc/1yvfiz0
thanks
garmin edge 530
taylorgodiva
Re: garmin edge 530
There is a bug in the original flywheel table/spec from Elite, which doesn't actually include the weight of the disc. They are currently updating their specs to match the regular specs. So it actually weighs 5.1kg (not 4.5kg as originally announced), so it's 21.5% taller than the Direto X. Hope you get the problem fixed soon.
Geometry Dash Scratch
