Does anybody know if the powermeter in the directo xr model is affected by oval/osymetrics chainrings?
Most powermeter are affected in their measurement.. But unsure if this also is the case with the directo xr?
Because if it is, i am thinking about buying a suito instead! (if the power accuracy isent accurate no matter what)
I really apreciate any thoughts!
All the best Malte
Osymetrics/oval chainrings and powermeter in Directo Xr
maltetherkildsen
Re: Osymetrics/oval chainrings and powermeter in Directo Xr
Hi Malte
It may be a problem for the power sensors that measure power on the crank.
But Direto XR measures the torque on the hub, so the oval chainrings won't be a problem.
The only problem you may have is on cadence.
In fact, Direto XR uses a sensorless cadence algorithm which calculates cadence basing on microvariations that appears on speed when you give a pedal stroke. With oval chainrings, the shape of these variations may be different and this can make the algorithm fail (maybe not, but it's a possibility).
In this case you will solve this problem simply adding an external cadence sensor.
