Good day all.
I recently bought the above trainer for my 29er mtb. I have a 29er wheel with an indoor tyre mounted on the bike. I noticed in the manual there is a 30 diameter roller and 45 diameter roller setting. I am however not sure what the difference is and which setting the best is for my setup.
Can anyone please assist?
Thank you in advance.
Qubo power mag smart trainer
Re: Qubo power mag smart trainer
It's the elastogel roller diameter. This setting is important only if you connect the trainer on a non Elite device (for example a Garmin device), where you have to set the circumference value accordingly.
In your case, the Qubo Power Mag has a 45mm diameter roller.
Thank you so much.
