Elite Direto Firmware and Turn off
jose84
Postby jose84 » Fri Oct 20, 2017 11:13 pm
Hello
I just recieved my new Direto and maybe I have two stupid questions:
1. No where in the documentation I found anything about something simple as Turn off, It says goes to "Sleep mode" but nothing else, is just a simple unplug from the electrical/enery wall plug?
2. How I can check that I have the latest version of firmware on my trainer?
J.
Re: Elite Direto Firmware and Turn off
Postby Elite Admin S » Tue Oct 24, 2017 11:34 am
Direto doesn't have a switch to turn it off. You can decide if wait the stand-by mode or unplug it (best solution to avoid storm damages).
About the firmware, by now there is only one firmware for Direto so... you have the last one! ;)
By the way, in the future we will release an app that will check the firmware status of the trainer and eventually upgrade it.
jose84
Postby jose84 » Tue Oct 24, 2017 2:01 pm
Hello
Many thanks for the reply, actually I fond out that the Direto after a while of no use will shutdown itself. Also, thanks for the info about the firmware.
Now, I got another issue, I have my Garmin Edge 810 and I would like to pair manually the Direto since I got another Power meter next to it, where I can find this ID?
J.
Postby Elite Admin S » Thu Oct 26, 2017 10:44 am
Hi J.
Garmin Edge 810 doesn't support the fe-c trainers. You can connect to it only as a speed&cadence sensor + power sensor.
I don't know if this is the information you need.
jose84
Postby jose84 » Thu Oct 26, 2017 10:50 am
Hello
I found the ID for connecting manually to my Garmin 810, you need to take the cover of the leds and you'll dine the ID tag.
Thanks!
Return to “Direto”
