Issue fitting my bike - between <28" and > 28"
Posted: Tue Dec 22, 2020 10:01 pm
by punky
Hi all,
I have a Elite Tuo and my bike is a hybrid with a 700c with 35c trainer tyre.
Following DC Rainmaker's instructions I tried the <28" installations but as far back as the trainer would go, it was too tight for the wheel (i.e. the roller should be lightly skimming the wheel before clamping).
I then tried the > 28" installation. At first I managed to get my bike in OK, but after like 30 mins when I tried calibrating it, I couldn't get the roller close enough.
Which installation method should I be using and does anyone have any tips for getting my bike in properly?
Thanks.
Re: Issue fitting my bike - between <28" and > 28"
Posted: Mon Dec 28, 2020 6:11 pm
by okhomenko
I am having exactly the same tires and same issue. I initially installed >28" because it was default instruction and I had no idea about size of my tires :D
It worked pretty well, on hard sessions, standing position etc. Although I couldn't get calibration working
Today I changed position to <28 and calibration finished fine, although I haven't tried to do my workout yet.
Posted: Sat Jan 09, 2021 2:08 pm
by punky
Thanks!
How did you manage to get the roller back far enough? I can't seem to get it back far enough to get the trainer clamped to the frame?
Posted: Thu Oct 21, 2021 5:08 pm
by Hatti
Having the same issue here trying to setup.
Tire is 27.5", if I use <28" I can't bring the frame close enough to lock it in because the tire hits the roller, if I use >28" I can lock it in but not bring the roller close enough :/
Any help? Roller still comes to contact when I bring it in, but feels like it's not giving enough traction.
Posted: Fri Oct 22, 2021 9:58 am
by Elite Admin S
Before fixing the bike, you have to move back the unit of resistance using the knob.
Here's two interesting articles on how to fix it properly:
https://elitesrl.zendesk.com/hc/en-us/a ... uo-trainer
https://elitesrl.zendesk.com/hc/en-us/a ... r-workouts
Posted: Fri Oct 22, 2021 11:37 am
by Hatti
Ok I've figured it out,
I had to manually push the unit with my hands to bring it backwards after rotating the knob anti-clockwise when using the <28" slot.
