Elite Suito - Adjusting rear derailleur non resistance mode
mnozin
Re: Elite Suito - Adjusting rear derailleur non resistance mode
Postby mnozin » Fri Jan 08, 2021 4:09 pm
I tried single segment with -30 slope still a bit too hard to spin. Elite, this is a bug.
james722
Postby james722 » Wed Jul 21, 2021 11:21 pm
I’m having the same issue.
Anyone found a solution to this problem?
Postby Elite Admin S » Thu Jul 22, 2021 8:08 am
The trainer has an internal flywheel, which is quite heavy. That ensure a good and realistic feeling when you pedal on a training session.
On the other side, this means that you have to win the flywheel resistance when you start pedaling.
So, if you have to do any adjustment to the derailleur, it's not easy to rotate manually the pedals.
You need necessarily to mount on the bike (or ask someone to pedal on it while you do your adjustments)
litewka.szymon
Postby litewka.szymon » Sun Jan 02, 2022 7:46 pm
I have the same issue here, how to adjust derailleur in elite suito? I am not able to ask anyone for pedaling...
jopy6
Postby jopy6 » Wed Dec 21, 2022 4:13 pm
I will assume nothing yet!!!???
