Elite Suito - Adjusting rear derailleur non resistance mode
Re: Elite Suito - Adjusting rear derailleur non resistance mode
I tried single segment with -30 slope still a bit too hard to spin. Elite, this is a bug.
I’m having the same issue.
Anyone found a solution to this problem?
The trainer has an internal flywheel, which is quite heavy. That ensure a good and realistic feeling when you pedal on a training session.
On the other side, this means that you have to win the flywheel resistance when you start pedaling.
So, if you have to do any adjustment to the derailleur, it's not easy to rotate manually the pedals.
You need necessarily to mount on the bike (or ask someone to pedal on it while you do your adjustments)
I have the same issue here, how to adjust derailleur in elite suito? I am not able to ask anyone for pedaling...
I will assume nothing yet!!!???
Users browsing this forum: No registered users and 42 guests
