NEW INTERACTIVE TRAINER - DIRETO
Postby Elite Admin S » Mon Jul 10, 2017 10:05 am
Elite welcomes DIRETO.
This new direct drive joins the whole range of full interactive trainers that Elite proudly boasts.
Direto will be released around September and can already be tried during Eurobike 2017 (Friedrichshafen, 30/08 – 02/09).
ELITE DIRETO. Interactive & Easy Training.
INTERACTIVE TRAINER
Direto is a new totally interactive ANT+ FE-C & Bluetooth home trainer, compatible with Elite software and with the other most used platforms such as for example Zwift, TrainerRoad, the Sufferfest, Kinomap and Bikevo.
SLOPE AND POWER
It simulates challenging slopes, up to 14%, with a 1400 Watt power output at a 40 km/h speed.
PEDAL ANALYSIS
One of the best things about this totally interactive home trainer is its integrated OTS (Optical Torque Sensor) power meter, which measures power with +/- 2,5% accuracy. DIRETO’s pedaling analysis option (available as an in-app purchase) measures power during the whole pedaling movement and sets 12 points that determine how much effort you put in your legs, so you can optimize your training session. The My E-Training software and app with pedaling analysis option (available as an in-app purchase) displays DIRETO’s measured power data on two different types of charts.
COMPATIBILITY WITH BIKES
It is compatible with both road and MTB frames, including 142 x 12 with thru axles.
EASY TO SET UP
Direto is a direct drive that allows an easy set-up and avoid tyre wear or slippage.
TECH INFO
Home trainer type: Interactive direct transmission with electronically managed magnetic brake
Power monitor: Integrated OTS (Optical Torque Sensor) power meter
Power measurement accuracy: +/- 2,5%
Wireless transmission: ANT+ (FE-C, Power and Speed & Cadence) and Bluetooth
Max slope: 14%
Max power: (40 km/h) 1400 Watt – (60 km/h) 2200 Watt
Management via: Smartphone, tablet, ANT+ FE-C and Bluetooth bike computers
Compatible with: My E-Training software & app, Zwift, Trainerroad, Bikevo, Kinomap, Sufferfest…
Output: Power, speed and cadence
Flywheel: 4,2 kg, high RPM
Bike compatibility: Road, Mountain and city bikes (including carbon ones), with 130-135 x 5mm hubs and quick release and 142x12 with thru-axle
Sprocket cassette compatibility: Shimano 9/10/11 speed, SRAM & Campagnolo 9/10/11 speed. –An adapter that's available from your local Elite dealer or http://www.shopelite-it.com is required for compatibility with Campagnolo
Connection: Power supply, ANT+ and Bluetooth (3 LED lights)
Firmware update: Yes
Includes: 12-month free subscription to the My E-Training software & app
Available on: Smartphone, tablet, bike computers, sport watches, ANT+ and/or Bluetooth computers
Electrical requirements: input 100-240 volt 50-60hz 6A - output 12V 1.5A
Space occ. when unfolded (lxd): 840 x 650 mm (33.07 x 25.59 in)
Height: 550 mm (21.65 in)
Space occupied when folded (lxdxh): 300 x 650 x 550 mm (11.81 x 25.59 x 21.65 in)
Weight: 15 kg (33.1 lbs)
DIRETO web page: http://www.elite-it.com/en/node/21331
DIRETO presentation: http://www.elite-it.com/sites/default/f ... tation.pdf
DIRETO tech info: http://www.elite-it.com/sites/default/f ... info_0.pdf
