real emotion resposiveness
loki
Postby loki » Mon Jun 26, 2017 10:00 am
i noticed a lag of 1-2 seconds until the magnet gives me the resistance of a slope in zwift ... is there any possibility to fasten this procedure ?
Re: real emotion resposiveness
Postby Elite Admin S » Mon Jun 26, 2017 12:33 pm
It is due to how the trainer is made.
The trainer has a magnetic arm moved by a step motor, so it takes some seconds to put the arm in the correct position.
If you have a b+ version or an ant upgradable version of the firmware, you can indeed speed it up a little.
In this case, here's the link on how to do it (look for the part related to modification of the resistance variation speed:
http://com.elite.realaxiom.static.s3.am ... _eng_5.pdf
loki
Postby loki » Tue Jul 04, 2017 11:26 am
i have the b+ version and downloaded the tool for the b+ version but it told me that the trainer is not supported.
Postby Elite Admin S » Tue Jul 04, 2017 11:39 am
Sorry, I've verified and Real Emotion is already at its maximum speed.
This part of the procedure is almost only for Real Turbo Muin.
I'm sorry, it's not possible to speed it up.
Postby Elite Admin S » Thu Jul 06, 2017 8:17 am
@loki,
Good news!
I've talked with the developers again and they told me that they can indeed speed it up a little!
They are modifying the upgrade program to enable this option, I think it will be ready already tomorrow :mrgreen:
So, thank you for your request ;)
Postby Elite Admin S » Thu Jul 06, 2017 8:44 am
The modified version is online!
Download it again and try, let em know if it works!
loki
Postby loki » Tue Jul 11, 2017 12:17 pm
gonna try it out !
loki
Postby loki » Tue Jul 11, 2017 7:11 pm
non conesso
Postby Elite Admin S » Wed Jul 12, 2017 8:20 am
The Real software was closed when you run the upgrade program?
Are you sure that your trainer was not connected to something else (app or devices)?
Return to “Real trainers”
