The Elite web site states "A Campagnolo compatible 9/10/11 speed cassette freehub is available as an option", however I cannot find any additional information on how to exactly use the Drivo with a Campagnolo cassette.
Is this Campagnolo compatible freehub included in the box or do I need to order an additional component? If yes, what is the reference of this component? Additionally, is there an installation procedure included or does the installation have to be performed by the dealer?
Drivo and Campagnolo9/10/11 speed cassette
Re: Drivo and Campagnolo9/10/11 speed cassette
I confirm you that the cassette is not included in the package.
Here's the link of the part in our online shop:
https://www.shopelite-it.com/en/spare-p ... le-version
It is very easy to install. You have only to unscrew the nut, extract the free hub and replace it with the new one.
Thank you for your reply, I have in the mean time ordered and received a Campagnolo freehub.
Replacement of the original hub was, as you had stated, very easy and quickly to do.
Overall, I am very pleased with my Drivo so far however I consider the omission of not including a quick release skewer an improvement point, after all, the Drivo is the top of the line! Nobody wants to go to the hassle of having to order and waiting for the arrival of a separate skewer when their brand new Drivo is sitting there doing nothing Also, it would be nice if Elite could throw in some addition stickers (marketing).
Cheers
Cheers
I'm going to forward your suggestion to the marketing guys
Do you need to fit any spacers on a 10 speed campy cassette??
Dear GuyM and Admin,
I just got a Drivo 2, Campagnolo cassette adapter and I beg to disagree on the supposed ease of installation: the replacement hub won't fit on the Axle.
Regards,
Eric
Regards,
Eric
