Software Clunk Sound
Posted: Mon Nov 19, 2018 8:55 pm
by watherton
I've had my Elite Drivo II for three hours, and when setting everything up, I heard a real strange electronic clunk sound. Thinking that this was perhaps a firmware issue, I searched high and low to find how to update the firmware, only to find, that you couldn't do this by the means of MyEtraining app. Seriously, a £1000+ purchase and no way of updating the firmware!!!
Anyways, apart from this oversight, has anyone else encountered this noise before? it happens during pedal strokes and when a stop pedalling.
One other point, when in ZWIFT, I'm presented Elite FE-C 2071 for Controllable and Elite Pwr 2071 - Which one do I select, switching between the two doesn't present any cadence output, even though I have the supplied cadence adapter on.
Re: Software Clunk Sound
Posted: Fri Nov 30, 2018 1:46 pm
by Elite Admin S
The sound you hear probably is the internal motor that adjusts the resistance, I think.
But it shouldn't be loud. I suggest you to contact our customer care at myetraining@elite-it.com adding a short video, so we can hear the noise level.
About the firmware, your sentence is not correct.
The firmware is upgradable, but:
- in this moment, only we can do the upgrade (it's not yet an operation that can be done freely by a customer... not yet)
- you shouldn't need any upgrade; if there's an unusual sound/noise, it's not something that can be solved by a firmware (must be something mechanic)
Finally, about Zwift, you have to select the one with the "fe-c" word on it.
If you still cannot see cadence, please contact Zwift customer care
