can't pair garmin HRM RUn HR band
Posted: Sun May 14, 2017 12:19 am
by rafael16
Hello everybody
Greetings from Chile
Just bought an Elite Qubo Digital which says to be BT and Ant+ compatible.
During setup I tried to pair my Fenix 3HR HR-RUM band with the digital unit with no success. I get Err, press the left button to pair again and continually get the Err message.
Please Advise
Best Regards
Rafael
Re: can't pair garmin HRM RUn HR band
Posted: Mon May 15, 2017 8:21 am
by Elite Admin S
Hi Rafael
If you have the handlebar console, it means that you have the Qubo Digital (first version), which doesn't have the bluetooth compatibility.
It uses a proprietary ant protocol.
The old Qubo Digital can be coupled with any ant+ heart rate transmitter.
I don't know how your Fenix works, unfortunately. Please contact Garmin and ask them if the device transmits externally an ant+ heart rate signal.
If it is so, you should be able to couple it.
