Doesn't turn on
Posted: Tue May 09, 2017 1:35 am
by pwetzlar2
Hi there
I used my trainer a couple of days ago and today, when I connect it to the power supply, it makes a constant louder noise than usual and the red light inside doesn't turn on.. I tried to connect in different power plugs at home and the same thing happens. Can someone help me with that?
Cheers
Peter
Re: Doesn't turn on
Posted: Tue May 09, 2017 8:15 am
by Elite Admin S
Probably the electronic board has broken.
Please contact the customer care at real@elite-it.com and explain the situation, they will tell you how to procede.
Remember to add information on the trainer (model and serial number)
