https://100001.onl/ https://1921681254.mx/
Since yesterday, the simulation of routes works
Resistance ..... downhill = slight resistance) not more. No matter was for one
Route is simulated, the resistance always remains the same. Engine flywheel
makes sounds like he's simulating it. I'm currently in training for
a marathon and a longer driving and training break are not conducive.
thanks.
Qubo Digital smart B+ Problems
harawalamaalchaiye
Last edited by harawalamaalchaiye on Tue Oct 12, 2021 2:36 pm, edited 1 time in total.
Re: Qubo Digital smart B+ Problems
Run my e-training and select level mode
Pedal at constant speed and increase gradually the level.
If you don't feel the resistance change, it means that there's a problem on the motor or on the electronic circuit board
In this case, contact us:
