Hello.
Maybe some of you folks have figured out how to set the trainer in the 0 resistance mode, because Elite didn't help me either through e-mail nor telephone.
I want to adjust rear derailleur, but to do that I have to set the chainring to the strongest gears - and easily pedalling is impossible, hence the adjustment becomes a pain in the ass. I tried my E-Training app, and set power in training mode to "1", but it still does resist quite a lot.
Howto?
Thanks!
Elite Suito - Adjusting rear derailleur non resistance mode
markuszewski.maks
dldproductions
Re: Elite Suito - Adjusting rear derailleur non resistance mode
Did you figure this out? I'm having the same issue
geraldbardini
Same issue for me, Elite team, do you have a solution?
I'm currently dealing with the same issue. Did you manage to find a solution for this? Elite support has not answered yet...
turgaysahna
did you find any solution
There are a lot of different bikes with different derailleur.
So, every single case must be analyzed.
Please contact our customer care at myetraining@elite-it.com adding some photos, the guys there will give you instructions
turgaysahna
Is there a mod in Wahoo kickr in Suito?
Derailleur adjustment
The resistance in suito is so high that we cannot pedal manually.
https://www.youtube.com/watch?v=xkdrJVynPsE
bodonoghue
I have the same issue, has anyone found a solution, as opposed to the stock answer Elite Admin?
mtrzaska.spam
Hi guys,
Same issue here. Is there a way to put Elite Suito in "0" resistance mode (no resistance at all) for gear indexing? It's almost impossible to make it now as there is quite big resistance
I have tried to connect to my elite app and switch the trainer off but it does not work.
Help guys, I can see that it is a common issue here.
And it is not related to my gear, I just want Elite Suito to be put in no resistance mode.
M.
M.
Wondering if a custom workout can be created with some kind of constant downhill which will reduce resistance. I am new to it. Can anybody think of anything here?
