Direto XR led lights
stephenchaplin77
Hi I'm new to smart trainers but the blue and green led lights on my trainer are still blinking even after calibrating the power sensor through my Garmin edge 1030 and running the calibration procedure on the my e training app. Is this normal or should the lights have changed to constant ? I'm sure in the manual it says they should be constant. It says if they are blinking the trainer is waiting to connect? Can anybody tell me what Im . Doing wrong please?
Re: Direto XR led lights
Hi. I have the same issue. Did you ever get an answer from anyone ?
Not exactly... it depends if you use bluetooth or ant+ protocol.
If you use bluetooth protocol, the blue led is blinking while waiting for the connection and become stable when the pairing is done.
If you use ant+ protocol, the green led blinks even after the pairing and become stable only when it receive the first resistance command (so, when you start a training)
