I just purchased the Qubo Digital Smart B+. I am set up as follows:
* - Windows Laptop without Bluetooth;
* - Zwift Companion running in my Galaxy S7.
I can connect to Zwift. I am connected via Power Source, Controllable and Cadence.
Everything seems to work fine except there is no change in resistance regardless of the incline/decline. I have adjusted the resistance setting but there is no change.
Thoughts?
No resistance when using Zwift via Bluetooth!!
jobinarwan
jacksonmonroes
Re: No resistance when using Zwift via Bluetooth!!
jobinarwan wrote:I just purchased the Qubo Digital Smart B+. I am set up as follows:
I can connect to Zwift. I am connected via Power Source, Controllable and Cadence.tweakbox appvalley https://vlc.onl/
Thoughts?
got the same issue!!
fredrik.blad
I have the same problem. Anyone know how to fix it?
