How to pair the Elite Square Buttons with Zwift?
ralf.proplesch
How do I connect the Buttons of the Elite Square with Zwift ?
lubos.olejar
Re: How to pair the Elite Square Buttons with Zwift?
I believe not possible at the moment. Also I didnt find way how to change shifting mode. Default is Shimano mode. I am used to SRAM ... Then when you connect via app to square there is in app option to test buttons ... it doesnt work, after while I get error message that some buttons are not working. Software is half baked and and long road ahead.
Yes these buttons do not have many functions in this current stage. But at least the virtual shifting is working well and I could replicate the gears of my bike. So now I use the square with the Zwift play controllers together
You can connect the buttons of the Elite Square with Zwift by pairing it through Zwift’s settings under the "Controllers" or "Steering" section — just make sure your device's Bluetooth is turned on and the Elite Square is in pairing mode!Monkey Mart Game
Speed Stars Have you encountered any specific issues, such as buttons not being detected or error messages in the Elite Square app?
To connect the Elite Square Buttons with Zwift, follow these steps:
Ensure Compatibility: Make sure your Elite Square Buttons are compatible with Zwift.
Bluetooth Connection: Turn on Bluetooth on your device and put the buttons in pairing mode.
Open Zwift: Launch the Zwift app and go to the pairing screen.
Select Devices: Look for the Elite Square Buttons in the list of available devices and select them to pair.
Test Functionality: Once connected, test the buttons to ensure they work properly with Zwift.
block breaker
block breaker
