Hi all,
I have just got a set of the Airon Digital roller. Not the smart ones but the older model.
Can anyone tell me how to use the little computer that comes with the rollers. It’s the little control head unit.
I cannot get it to work and does not seem to connect to the rollers?
Can some tell me where the user guide is or help me setting it up please?
The settings screen has a param 1 screen but I do not know what this is. Also the pairing screen never pairs with anything?
Please help.
Andy.
Airon Digital - how to use the little computer
Re: Airon Digital - how to use the little computer
You can find all the instructions in the user manual.
If you cannot find the user manual, contact our customer care at real@elite-it.com and ask for it.
The user guide does not include the instructions for the commuter.
It only tells you how to set up the rollers.
Contact the customer care, we will send you the complete instructions
