Turbo Muin Knocking noise
Posted: Mon Oct 14, 2019 11:32 pm
by vincenzo.iaciofano
Hi, I hope you can help me. I bought a elite turbo muin less than two years ago thinking that i would have many years trouble free. Its started to make knocking noises. I can also feel vibration as I let the trainer free wheel. I assume its a bearing that has gone or could it be adjustment? I am looking for the original instructions or book to show how to adjust first? Hopefully this will cure the noise.
Vincenzo
(vinnychoff}
Re: Turbo Muin Knocking noise
Posted: Sat Oct 19, 2019 5:42 pm
Hi, I took it apart and have found that two sets of bearings have failed. The adjuster bearing has worn out and the main bearing on the shaft in the fluid. Is this normal after two years of service?
Regards Vincenzo
