Bluetooth - How to pair the trainer/sensor
Posted: Mon Jul 17, 2017 11:49 am
by Elite Admin S
A simple advice for those who are having problems connecting to the trainer or a sensor using Bluetooth ;)
Remember, don't use the Bluetooth settings menu of your device to connect, otherwise you'll get a reject message.
Simply run the app (My e-Training, Zwift or whatever program you're using) and do the configuration, the app will manage the connection by this own.
For example, if you are going to use My e-Training simply run the app, select Parameter, then Configure and follow the guided steps.
Have a nice training!
