Electricity build up with quick motion
Posted: Wed Dec 26, 2018 1:44 pm
by Jerome
Hi !
I got a set of Quick Motion rollers for Xmas which I tried this morning. After a few minutes I managed to ride them with both hands, so it is not as difficult as I was expecting, but I have a problem with static electricity building up while riding and everytime I touch the metal garage door I get a chock.
I was thinking about buying an antistatic wrist band to earth myself. Will it work ?
Cheers
Jay
Re: Electricity build up with quick motion
Posted: Thu Feb 21, 2019 4:12 am
by edwardphrase
How bad is the shock? If you wire your bike or wrist to the aluminum door, it will provide a circuit to continuously discharge .
Posted: Tue Mar 12, 2019 12:32 pm
by Elite Admin S
Humidify the room a little (this should help).
Also try changing your clothes and the tire ;)
Posted: Tue Mar 19, 2019 6:05 pm
by Jerome
Hello !
Thanks for your help. I got myself a cheap antistatic wristband and the problem is solved.
Cheers?
Jay
