Hi, I hope you can help me. I bought a elite turbo muin less than two years ago thinking that i would have many years trouble free. Its started to make knocking noises. I can also feel vibration as I let the trainer free wheel. I assume its a bearing that has gone or could it be adjustment? I am looking for the original instructions or book to show how to adjust first? Hopefully this will cure the noise.
Vincenzo
(vinnychoff}
Turbo Muin Knocking noise
Re: Turbo Muin Knocking noise
Hi, I took it apart and have found that two sets of bearings have failed. The adjuster bearing has worn out and the main bearing on the shaft in the fluid. Is this normal after two years of service?
Regards Vincenzo
Regards Vincenzo
Hello, I have the same problem. I have to change the bearings and fluid. I saw some youtube videos. I think to get the bearings isn't a problem, but the fluid. I don't know what kind of fluid and how much must be filled in. Can anybody help me? Thank you in advance Markus.
@klett.markus,
it's a special oil, you cannot using a different one.
https://support.elite-it.com
How do you overcome this issue? As a new user, I would like to know more about it. Thank you!
