Elite Novo Force x Misuro B+
cesar_basso
Postby cesar_basso » Sat Jun 06, 2020 9:10 pm
Hello everyone,
Does anyone has been facing some issues with inaccuracy information transited by Misuro B+, for instance (over estimate velocity/speed, cadence..)
Also, does anyone know how many light should blink in order to set up Misuro B+ with Elite Novo Force? There is no such info on the technical sheet.
Tks
Cesar
Re: Elite Novo Force x Misuro B+
Postby Elite Admin S » Fri Jun 26, 2020 10:52 am
Usually wrong data from misuro B+ are due to:
- wrong number of flashes set
- wrong position of the misuro (also orientation is important)
About Novo Force, you have to set 1 flash only (generic trainer).
If you still think that the data are not correct, please send a photo in which I can see the position of the sensor on the trainer
Return to “Other Trainers”
