Hi !
I got a set of Quick Motion rollers for Xmas which I tried this morning. After a few minutes I managed to ride them with both hands, so it is not as difficult as I was expecting, but I have a problem with static electricity building up while riding and everytime I touch the metal garage door I get a chock.
I was thinking about buying an antistatic wrist band to earth myself. Will it work ?
Cheers
Jay
Electricity build up with quick motion
edwardphrase
Re: Electricity build up with quick motion
How bad is the shock? If you wire your bike or wrist to the aluminum door, it will provide a circuit to continuously discharge .
Humidify the room a little (this should help).
Also try changing your clothes and the tire
Hello !
Thanks for your help. I got myself a cheap antistatic wristband and the problem is solved.
Cheers?
Jay
Cheers?
Jay
