Is anyone monitoring the forum?
I have technical support questions:
1 How can I maintain the Qubo Fluid Plus - It seems to make ecessive noises.
2. Can I grease it somehow?
3. Is there a user manual, and a technical manual
Please check this video I made of the problem
https://youtu.be/FS4m15YcBuU
Doug Smith
Quno Fluid + noisy roller
Re: Quno Fluid + noisy roller
Hi Doug,
I know nothing but that sounds awful!
Try getting in touch with the support people through the contact section
on the Elite website homepage. They got back to me very quickly when
I needed to know if my bike was compatible.
Good luck.
Jeanette
Good luck.
Jeanette
Yes i agree with above reply..U should contact officials..They are too quick in reciprocating u.They will definitely help u
harrycharlesop
I use an Elite Qubo fluid trainer which you can find for $150. The resistance is a bit inconsistent for the first few minutes until it warms up. Since it doesn't have a flywheel there's no feel of momentum like you get actually riding.
It's mind numbingly boring until I started using Zwift too. Just need a speed sensor and a device to run any training app on.
Rollers are more entertaining to ride but the cheap ones don't offer much resistance for high wattage intervals.
MyBKExperience MyBPCreditCard MyKFCExperience
nikhil@carmatec.in
Thanks for this info. Cheers to all & happy holidays to everyone
Last edited by nikhil@carmatec.in on Sat Mar 08, 2025 7:45 am, edited 1 time in total.
mayomayo72218
Try contacting the support people through the contact section. I look forward to how you solve this problem!
Vampire Survivors
Vampire Survivors
lawleitl22
Nice post. I was checking constantly this blog and I am impressed! Extremely helpful information especially the last part I care for such info a lot.
Thank you and good luck.
