desire to zoom in on part of route while on trainer
Posted: Mon Mar 13, 2017 10:19 pm
by johnromeronc
I am using software ver 7.2.0.77. I have imported some routes which worked well. Some of them are long 50 miles and more. I would like the ability to have the display show only a use set # of miles / KL at a time with a small window showing where I am in the entire ride. For example. The larger window or a split window would show 5 miles so I can see a little more details on when a climb is coming and how long it will be. and then another window that shows the entire ride. If a two window user interface is not possible, then the ability to set either via a +/- zoom selection on the screen, so it can be set before the ride starts. If I am setting up a 100 mile ride, then the slope up / down is a very short unusable visual.
Thanks for your time
John
Re: desire to zoom in on part of route while on trainer
Posted: Thu Mar 16, 2017 9:13 am
by Elite Admin M
Thanks, your suggestions will be forwarded to the development team.
