The Real Software wired does not work in W10
treino
Postby treino » Sat Aug 11, 2018 4:58 pm
Since I had a update in W10 the "Real for Realaxiom wired v. 8.0.0.44 does not work, there's way to fix it?
Re: The Real Software wired does not work in W10
Postby Elite Admin S » Tue Aug 28, 2018 9:26 am
It may be due to port COM number.
Please download this file (it's an empty txt file, don't worry about it) and copy it on the same folder where the Real.exe file is:
https://drive.google.com/open?id=0B2n_H ... 1VsZnZWZ0E
Then, open windows device manager and check which number of COM port uses the console.
If it is equal or lower than 3, change the COM number and set it at 4 or higher.
Then run the software and all should work properly.
tobbe.uppsala
Postby tobbe.uppsala » Sat Nov 03, 2018 11:17 am
Need instrucions om how to do this:
...open windows device manager and check which number of COM port uses the console.
Bryan431
Postby Bryan431 » Fri Jan 04, 2019 10:19 am
There could be various reasons as to why the Ethernet not working issue is residing on your computer. Based on these reasons, you should take the actions. You first have to try the common solutions that work for most of the users
alanperker007
Postby alanperker007 » Fri Jan 11, 2019 10:37 am
I have encountered with a wired problem which was generating in the windows 10 but in window 7 it was working fine. The software problem may be due to a different reason.
adasmith
Contact:
Postby adasmith » Tue Jun 01, 2021 9:37 am
I also use window10.
Jane8
Postby Jane8 » Sat Jul 31, 2021 9:22 am
It may be due to port COM number. Then, open windows device manager and check which number of COM port uses the console. If it is equal or lower than 3, change the COM number and set it at 4 or higher. Then run the software and all should work properly.
