Hi. I have the quip power mag trainer
Can you please tell me what is the difference mounting the device on the base on the 30 or 45 degrees bolt holes ?
Thank you
Qubo power mag smart
Re: Qubo power mag smart
30 and 45 are referred to the roller dimension.
So, in your case you have to follow the instructions related to 30mm roller to find out the correct bolt holes.
